How to run an extarnal Ilogic run using VBA Marco
Darkforce_the_ilogic_guy
Advisor Advisor
I want to make a bottom/Marco that run an Extarnal ilogic rule call SurfaceColour.
I have try some stuff found of the web about it ... but it does not seens to work.
how do I do it ?
Sergio.D.Suárez
Hi,  for a while I have had this macro that worked very well, stop using it for the work that requires go for each PC and accommodate all the custom tools, I get used to using external rules.
In red is the name of the external rule that you must put in quotation marks,
You must specify a macro name, I use for example RuleA and Rule B, you can create many macros and then add the macro to a custom button from customize user command
Public Sub RuleA() ' <--- This is what you would tie to a button in a toolbar.
RuniLogic "RulenameA"
End Sub
Public Sub RuleB() '<--- This is what you would tie to a button in a toolbar.
RuniLogic "RulenameB"
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
Dim iLogicAuto As Object
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
If oDoc Is Nothing Then
MsgBox "Please Open Document"
Exit Sub
End If
Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Set addIns = oApplication.ApplicationAddIns
'Find the add-in you are looking for
Dim addIn As ApplicationAddIn
On Error GoTo NotFound
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
If (addIn Is Nothing) Then Exit Function
addIn.Activate
Set GetiLogicAddin = addIn.Automation
Exit Function
NotFound:
End Function
I hope it helps to solve your problem, greetings
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
chandra.shekar.g
Autodesk Support
Autodesk Support
@Darkforce_the_ilogic_guy,
Try below VBA code to run external iLogic rule.
Public Sub Internal_iLogic()
    Dim addIns As ApplicationAddIns
    Set addIns = ThisApplication.ApplicationAddIns
        For Each addIn In addIns
            If InStr(addIn.DisplayName, "iLogic") > 0 Then
                            addIn.Activate
                Set iLogicAuto = addIn.Automation
                Exit For
            End If
        Next
    Debug.Print addIn.DisplayName
    Dim RuleName1 As String
    EXTERNALrule = "3D PDF"
    Dim RuleName2 As String
    INTERNALrule = "Rule2"
        MsgBox "Missing Inventor Document"
        Exit Sub
      End If
    'iLogicAuto.RunRule oDoc, INTERNALrule 'for internal rule
    iLogicAuto.RunExternalRule oDoc, EXTERNALrule 'for external rule
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
