use Logic to change color of an assambly
Darkforce_the_ilogic_guy
Advisor Advisor
How do I change color of an assembly change color to "RAL 7035" ?
 I need to work on all Assembly
And to use Ilogic and I use before save
Sergio.D.Suárez
This rule changes the color of all occurrences of the assembly, select the default library color, do not put your color because my library does not have it, and to test the code I assembled it (I tried it and it worked for me)
Dim oAsset As Asset
Dim oAsset_Array As New ArrayList
For Each oAsset_Array_X In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
oAsset_Array.Add(oAsset_Array_X.DisplayName)
oAsset_Array.Sort()
Next
'present the user with the list to choose from
100:
oAsset_Array_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oAsset_Array, oAsset_Array.Item(0), "TEXTURE SELECTION", "LIST OF TEXTURES")
If oAsset_Array_Selected = "" Then GoTo 100 :
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
	Component.Color(oOccurrence.name)=oAsset_Array_Selected
	iLogicVb.UpdateWhenDone = True
Next
I guess you should have a line something like this
	Component.Color(oOccurrence.name)="RAL 7035"
Next
I hope it helps to solve your problem, greetings
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks that was just what I needed to do the next step in the Ilogic code I am working on... Do you know way it come with I warring that it only works in Assambly ? I have found a workaround ... by simple make it a standalone code aand  just make my other code run it when needed ... but I would love to be enable to use it at one code without the warring
please excuse me @Darkforce_the_ilogic_guy  , but the language barrier does not allow me to understand exactly what you are looking for, if you explain in more detail I would like to help you in something.
Mechanical Designer
chandra.shekar.g
Autodesk Support
Autodesk Support
@Darkforce_the_ilogic_guy,
Hoping that below iLogic code helps to change asset only for assembly component in assembly.
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmDef As AssemblyComponentDefinition
oAsmDef = oAsmDoc.ComponentDefinition
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
Dim localAsset As Asset = Nothing
Try
	localAsset = oAsmDoc.Assets.Item("RAL 7035")
Catch
	Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
	Dim libAsset As Asset = assetLib.AppearanceAssets.Item("RAL 7035")
	' Copy the asset locally.
	localAsset = libAsset.CopyTo(oAsmDoc)
End Try
Dim oCompOcc As ComponentOccurrence
For Each oCompOcc In oAsmDef.Occurrences
	 If oCompOcc.ReferencedDocumentDescriptor.ReferencedDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		 oCompOcc.Appearance = localAsset
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
it is ok. the code you give me. did the part I needed help with.
I did only need help with part of my code. And your code did that i needed.
my complete code ... Ask the user to add a surface to custom Iperperties... IF the part or assambly is Raw, Colour 1, and so on.
with the new code i add ... it now change the colour of the part or Assambly to the Colour that it would have .. withour the user have to do it them self... and it change this in all view.
but most of the other just I already know how to do
