This rule changes the color of all occurrences of the assembly, select the default library color, do not put your color because my library does not have it, and to test the code I assembled it (I tried it and it worked for me)
Dim oAsset As Asset
Dim oAsset_Array As New ArrayList
For Each oAsset_Array_X In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
oAsset_Array.Add(oAsset_Array_X.DisplayName)
oAsset_Array.Sort()
Next
'present the user with the list to choose from
100:
oAsset_Array_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oAsset_Array, oAsset_Array.Item(0), "TEXTURE SELECTION", "LIST OF TEXTURES")
If oAsset_Array_Selected = "" Then GoTo 100 :
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
Component.Color(oOccurrence.name)=oAsset_Array_Selected
iLogicVb.UpdateWhenDone = True
Next
I guess you should have a line something like this
Component.Color(oOccurrence.name)="RAL 7035"
Next
I hope it helps to solve your problem, greetings
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
