How to prevent parameter (prefilled by iLogic rule) exceeds another keyparameter
BRLMCHKD
BRLMCHKD
Hi Forum.
Could anyone give me a idea, how I do make sure, that my parameter
'LinerDiaMachined' (prefilled by rule) never exceeds another key-parameter 'LinerDia'
see attached screenshot.
BRL
kelly.young has embedded your image for clarity.
johnsonshiue
Hi! I guess you may need to add a conditional statement in the iLogic rule to prevent the input parameter from exceeding the key parameter. I am not sure if there is a way to set a dynamic range in the UI. But, having a maximum value should be doable.
Many thanks!
Software Test Engineer
Curtis_Waguespack
Hi @BRLMCHKD,
Something like this would work. I've taken some guesses as to the intent, so adjust as needed.
Also just as a tip, programming questions of this type are likely better placed on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Answer = MessageBox.Show("Liner requires machining!", _
"Attention",MessageBoxButtons.YesNo,MessageBoxIcon.Exclamation)
If Answer = vbYes Then
	LinerDia = InputBox("Diameter OD", "Liner Machined", )
	If LinerDiaMachined > LinerDia Then
		LinerDiaMachined = LinerDia - 0.125
		MessageBox.Show("Machined diameter cannot exceed OD." _
		& vbLf & "Machined diameter adjusted to: " & LinerDiaMachined , "ilogic")
Else
	MessageBox.Show("Change ratio ...", "ilogic")
mcgyvr
I went with this "While" statement..
 Needs a LinerDiaSet True/false parameter
It will keep prompting for the value until it meets the "less than" condition...
Answer1 = MessageBox.Show("Set diameter for liner machining operation? ", "Set diameter" ,MessageBoxButtons.YesNo)
If Answer1 = vbYes Then
	LinerDiaSet = False
While LinerDia < LinerDiaMachined Or LinerDiaSet = False
	LinerDiaMachined = InputBox("Enter LinerDia . Must be less than " & LinerDia, "Title", "1")
	iLogicVb.UpdateWhenDone = True
 	LinerDiaSet = True
End While
Else
	Return
BRLMCHKD
Hi Johnson
Thank you very much 🙂
I will try some of the received suggestions right away.
Have a nice day.
KR Bent
dgreatice
I think this while will no end loop.
Try :
CheckAndGet = InputBox("Input", "Title", LinerDiaMachined)
CheckResult = False
Do Until CheckResult = True
	If CheckAndGet >= LinerDia Then
		CheckResult = False
	Else
		CheckResult = True
		LinerDiaMachined = CheckAndGet
Loop
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
