Global form edit iproperties parts in assembly
wouter
wouter
I'm having trouble editing some iproperties from parts that are in an assembly.
We all ready have a rule that fills in some iproperties in the parts run from an assembly, and now i wanted to add stuff like article codes for purchase parts.
Easiest way i thought would be a global form that is called on within the for each loop in our rule.
When i run the code in an assembly it does show the correct part info.
However if i fill in the boxes it changes the iproperties of the assembly instead of the part.
Now i created a workaround with an inputbox and writing the info to the parts iproperties using a local variable,
Leverancier = InputBox("Vul hier de levencier in van:" & vbLf & iProperties.Value("Project", "Stock Number") & vbLf & iProperties.Value("Project", "Part Number"), "Leverancier") iProperties.Value(BestandsnaamMetExtentie, "Project", "Vendor") = Leverancier
Long story short, is it possible to change iproperties from parts that are in an assembly via a global form?
kelly.young has embedded your images for clarity.
mcgyvr
In general to assign values to the iproperties of components you need to use this..
SyntaxEditor Code Snippet
iProperties.Value("part1:1", "Project", "Part Number")
vs
 Including your code is FAR better than including images..
Someone can just easily update your code for you vs having to guess what code you have..
wouter
Thank, but i allready used this in the workaround with BestandsnaamMetExtentie being a variable:
iProperties.Value(BestandsnaamMetExtentie"Project""Vendor")
But as far as i know you cant see code or do anything with it in a global form which i would prefer to use
