How to override a solid body color from an assembly
sergio_duran
sergio_duran
Hi everyone,
I would like to know how to override a solid body color from an assembly using either VBA (API) or VB.NET (iLogic).
There is another thread in which the color of bodies from a multi-body part are changed, then I adjusted it to do the same from the assembly but it changes the original body color rather than override it in the assembly level. In my code, I'm checking occurrence by occurrence, filtering only parts with more than one body, and finally, changing the color of solid bodies. It works well, but it changes the original color of every body.
Here is the thread
http://forums.autodesk.com/t5/inventor-customization/how-do-i-change-the-color-of-a-solid-in-a-multi...
iLogic has this snippet (please see below) to override a component color in the assembly level but the original color will remain the same.
SyntaxEditor Code Snippet
Component.Color("PartA:1")
I'd like to do something similar for solid bodies
Thanks in advance!
I've done something similar with Renderstyle. This is for a single part but I'm sure can be adapted for an assembly
'SET THIS PART AS STEEL (EN3B) BLACKENED
Dim oPartDoc As PartDocument
Dim oRenderStyle As RenderStyle
Dim oMaterial As Material
'Set the active Document
oPartDoc = ThisApplication.ActiveDocument
'Update material
iProperties.Material=("070M20 (EN3B)")
'Change Part Style
Try
    oRenderStyle = oPartDoc.RenderStyles.Item("Steel (Black)")
    ' Assign the render style to the part.
     oPartDoc.ActiveRenderStyle = oRenderStyle
    Catch
    MsgBox("Render Style cannot be found")
End Try
'Update Finish
Try
    iProperties.Value("Custom", "FINISH")="BLACKEN"
    Catch
    'Do Nothing
End Try
InventorVb.DocumentUpdate()
sergio_duran
Thanks! but the question is about color/appearance for Solid Bodies
Here's some iLogic code which I based on code from http://inventbetter.blogspot.com
' http://inventbetter.blogspot.com
Option Explicit
Sub Main
	Dim oAsmDoc as AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
	' Call the function which does the recursion
	Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences,1)
End Sub
Private Sub traverseAssembly(Occurrences as ComponentOccurrences, Level as Integer)
	' Iterate through all of the occurrences in this assembly.  Level 1 components
	Dim oOcc as ComponentOccurrence
	Dim oCompDef as ComponentDefinition
	Dim oAssy As Inventor.AssemblyDocument
	Dim oPart As Inventor.PartDocument
	Dim invCustomPropertySet As Inventor.PropertySet
	Dim sDescription As String
	For Each oOcc in Occurrences
		If (InStr(oOcc.Name, "BareCable")) > 0 Then
			' We have a conductor !
			' Get the selected  item document occurrence name
			oCompDef = oOcc.Definition
			oPart = oCompDef.Document
			invCustomPropertySet = oPart.PropertySets.Item("Design Tracking Properties")
			sDescription = invCustomPropertySet.Item("Description").Value
			Select Case sDescription
				Case "1192.5 KCMIL 61 AAC"
					'MessageBox.Show("1195.5 KCMIL 61 AAC", "Cadet Blue")
					Component.Color(oOcc.Name) = "Cadet Blue"
				Case "1192.5 KCMIL 38/19 ACSS/TW (STD STR)"
					'MessageBox.Show("1192.5 KCMIL 38/19 ACSS/TW (STD STR)", "Yellow")
					Component.Color(oOcc .Name) = "Yellow"
				Case "636 KCMIL 37 AAC"
					Component.Color(oOcc .Name) = "Red"
				Case Else
					Component.Color(oOcc.Name) = "Purple"
			End Select
		' Check to see if this occurrence represents a subassembly
		' and recursively call this function to traverse through it.
		If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
				Call traverseAssembly( oOcc.SubOccurrences, Level + 1)
	Next
End Sub
Could be helpful, or not.
sergio_duran
yosso22,
Thanks! but the question is about color/appearance for Solid Bodies. I need to override colors of bodies from Multi-body parts
Ahh...multi-body parts, missed that, apologize.
Here's a VBA example...that might help.
The asset VBA code came from the IV help file.
Option Explicit
Sub main()
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
    Stop
Dim assyDoc As AssemblyDocument
Set assyDoc = ThisApplication.ActiveDocument
Dim oAsset1 As Asset
Dim oAsset2 As Asset
On Error Resume Next
    Set oAsset1 = assyDoc.Assets.Item("Bamboo")
    Set oAsset2 = assyDoc.Assets.Item("Chrome - Polished")
    If Err Then
        On Error GoTo 0
        ' Failed to get the appearance in the document, so import it.
        ' Get an asset library by name.  Either the displayed name (which
        ' can changed based on the current language) or the internal name
        ' (which is always the same) can be used.
        Dim assetLib As AssetLibrary
        Set assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
        'Set assetLib = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9")
        ' Get an asset in the library.  Again, either the displayed name or the internal
        ' name can be used.
        Dim libAsset As Asset
        Set libAsset = assetLib.AppearanceAssets.Item("Bamboo")
        ' Copy the asset locally.
        Set oAsset1 = libAsset.CopyTo(assyDoc)
        Set libAsset = assetLib.AppearanceAssets.Item("Chrome - Polished")
        Set oAsset2 = libAsset.CopyTo(assyDoc)
    On Error GoTo 0
Dim oDef As AssemblyComponentDefinition
Set oDef = assyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
For Each oOcc In oDef.Occurrences
    Dim surBodies As SurfaceBodies
    Set surBodies = oOcc.SurfaceBodies
    Dim surBody As SurfaceBody
    For Each surBody In surBodies
        If surBody.Faces.Count > 3 Then
            surBody.appearance = oAsset1
        Else
            surBody.appearance = oAsset2
    Next
Next
End Sub
