Create Arbitrary View for DrawingView
JamieVJohnson2
JamieVJohnson2
I see there are a lot of unanswered posts for creating a custom view.  My problem sounds simple.  I have the view direction I want.  It is NOT a standard (front, left, right, top, bottom) direction.  I want to apply it to the document.  My failure is creating the camera object properly.  I have a target center, and a normal unit vector, but when my view is created I get a strange unusable (and massively large) view that tells me my camera is not correct.
How about some code:
  Dim sheet1 As Sheet = drawDoc.Sheets(1)
        Dim pViewPosition As Point2d = tg.CreatePoint2d(sheet1.Width * 2 / 5, sheet1.Height * 3 / 5)
        'choose base view rotation
        Dim viewOrientation As ViewOrientationTypeEnum = ViewOrientationTypeEnum.kArbitraryViewOrientation
Dim viewCamera As Camera = invApp.TransientObjects.CreateCamera() viewCamera.SceneObject = partDoc.ComponentDefinition viewCamera.ViewOrientationType = ViewOrientationTypeEnum.kFrontViewOrientation viewCamera.Target = FindMidPoint3D(partDoc.ComponentDefinition.RangeBox.MinPoint, partDoc.ComponentDefinition.RangeBox.MaxPoint) viewCamera.UpVector = sktNormal viewCamera.Apply()
Dim vBase As DrawingView = sht.DrawingViews.AddBaseView(docModel, pntView, dblScale, viewOrientation, viewStyle, strViewName, viewCamera, viewOptions)
I set to viewOrientation Notice there is not an 'eye' to the camera probably my problem, but I don't know what I should set it too.  I know the view will scale the document after I supply a scale, so can eye be target as well?  or should eye be target translated with up/normal vector to a point above the target?  This camera thing is difficult for me to process. Probably thinking too hard. Please help,
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
JamieVJohnson2
Solved my own problem...  Using the scientific method, I systematically turned off each option, and set one option at a time until I got what I wanted.  Turns out I got lucky pretty quickly this time.  So to create a camera of a view so that you can use it in a drawingview:
Get the normal of the view you want from a part component's planar sketch:
sktNormal = CType(skt, PlanarSketch).PlanarEntityGeometry.Normal
Create a camera object and populate its data and apply changes go camera:
        Dim pEye As Point = viewCamera.Target
        pEye.TranslateBy(sktNormal.AsVector)
        viewCamera.Eye = pEye
        'viewCamera.UpVector = sktNormal
        viewCamera.Apply()
Use camera to create view and set view orientation to kAbritratry...:
Manipulate scale to get the object to a preferred size (bonus code for being such a great audience):
 'rotate the view if necessary to make long horizontal
        If vBase.Width < vBase.Height Then
            vBase.RotateByAngle(DegreesToRadians(90))
        'scale the view down if necessary to meet limits
        If vBase.Width > viewWidthLimitInches * 2.54 Then
            Dim modWidth As Double = vBase.Width / vBase.Scale / 2.54
            For i As Integer = scales.Count - 1 To 0 Step -1
                Dim strSplit() As String = scales(i).Split("=")
                Dim top As Double = FeetInchToDecimalInch(strSplit(0))
                Dim bot As Double = FeetInchToDecimalInch(strSplit(1))
                If top / bot * modWidth < viewWidthLimitInches Then
                    strScale = scales(i)
                    Exit For
            Next
Fyi, our industry things in inches while Inventor thinks in centimeters hence the 2.54 everywhere.  In addition FindMidPoint3D, DegreesToRadians, and FeetInchToDecimalInch are custom functions I created.
Thank you, and come again.
