How to open the Parameters window from VB ...
Any example on VB / VBA / C# / C++
I need only interface name (from TLB) and function name for open Parameters window from external C++ code
dutt.thakar
@Anonymous
You can do it with control definition. Check out below link which is pointing in the same direction.
https://forums.autodesk.com/t5/inventor-customization/open-the-parameter-tool-via-vba/td-p/1706773
Hope it helps.
Hope it
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Thank you for the answer
I was looking for a slightly different solution
but this solution works too
I tested it on VBA & C++ code
Thank you again
