Obtain Absolute (x,y,z) Coordinates of point2d object
I have an application where I want to obtain the x,y,z coordinates of a point2d object with respect the origin (Centerpoint) of an inventor part. I tried to use the method the Addfixed method but that only works for a point object. I created a simple example (attached) of an extruded cylinder where I create a sketch and a point2d object of the face of the extruded cylinder. Please find attached file and sample code below.
Thanks!
Sub GetAbsCoordsOfPoint2DObject()
    Dim oPDoc As PartDocument
    Set oPDoc = ThisApplication.ActiveDocument
    Dim oPDef As PartComponentDefinition
    Set oPDef = oPDoc.ComponentDefinition
    Dim selectedFace As Face
    Set selectedFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select Face to place feature")
    Dim oWkPlanes As WorkPlanes
    Set oWkPlanes = oPDef.WorkPlanes
    Dim oWkPlane As WorkPlane
    Set oWkPlane = oWkPlanes.AddByPlaneAndOffset(selectedFace, 0, False)
    'Create and Define Sketch to be placed on working plane
    Dim oSketch As Inventor.PlanarSketch
    Set oSketch = oPDef.Sketches.Add(oWkPlane)
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oCoord0 As Point2d
    Set oCoord0 = oTG.CreatePoint2d(0, 0)
    Dim oCoord1 As Point2d
    Set oCoord1 = oTG.CreatePoint2d(1, 1)
    Dim oLine As SketchLine
    Set oLine = oSketch.SketchLines.AddByTwoPoints(oCoord0, oCoord1)
    Dim oWkPt As WorkPoint
    Set oWkPt = oPDef.WorkPoints.AddFixed(oCoord1, False)
End Sub
JelteDeJong
if you dont mind creating a SketchPoint you can use the following:
Dim sketchPoint As SketchPoint
set sketchPoint = sketch.SketchPoints.Add(oCoord0)
Dim pointInModelSpace As Point
set pointInModelSpace = sketchPoint.Geometry3d
the pointInModelSpace contains the x,y,z values of the point2D
Jelte de Jong
Blog: hjalte.nl - github.com
yes this is perfect!
Thanks!
