How to make NonParametricBaseFeature non translucent using VBA
I could not find any property nor method in VBA for doing this:
Part in question is imported .jt file.
BrianEkins
The API could be better for this but it is possible.  The thing in the browser that you select to set if it's translucent or not is a WorkSurface object.  What's missing in the API is the ability to get to the work surface from either the base feature or the body that was created.  If you're doing the import of the STEP then you can know that the work surface just created will be the last one.  The code below takes advantage of that.
Public Sub SetOpaque()
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    Dim comp As PartComponentDefinition
    Set comp = partDoc.ComponentDefinition
    Dim workSurf As WorkSurface
    Set workSurf = comp.WorkSurfaces.Item(comp.WorkSurfaces.Count)
    workSurf.Translucent = False
End Sub
Brian Ekins
Thank you for your reply. It worked.
