Inventor 202 does not release memory
Inventor 2020 is ramping memory and then never releasing it, even after all the files are closed (the files/occurrences count is 0/0). It seems that Inventor would only take what it needs, but as it takes more and more, it becomes less able to handle its own mess.  Constraints go wacky in both sketch and assembly. Inventor crashes at odd times, but the issue is occasionally repeatable.  The update that was just put out doesn't seem to address the issue.
Is anyone ELSE having this issue?
YuhanZhang
Recommend you to move this from Inventor Customization Forum (focus on Inventor API and iLogic issues)to Inventor Forum to get more response.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Jaroslaw.KrysiakM8KRR
Observer
Observer
I Have simmilar issue which shows up with using API.
I'm trying to do mass file generation based on ilogic driven assembly and model. Code running in assembly would iterate through all possible combination of 2 parameters (nested  "For" loop) generating new assembly, new drawing and generating PDF and STP. Code would close generated files before generating new ones. Unfortunately Inventor does not clear memory used and it would grow until crash (roughly after ~100 iterations).
API option to purge Inventor memory would be usefull in such situations
YuhanZhang
I agree if API can help to release memory would be useful, can you share a code sample to reproduce the memory leak issue? We can look into it further.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
