How to lock Rules in iLogic?
Pratik.Ksoni
Pratik.Ksoni
Could you please tell me that how to hide or lock rules in iLogic so that no one can edit or review?
Pratik
pball
I do not believe there is a way to prevent editing of ilogic rules.
There is an idea station post requesting this feature, so you might want to vote for it.
http://forums.autodesk.com/t5/inventor-ideas/ilogic-rule-lock/idi-p/5508287
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
MechMachineMan
For external rules you can just make the .txt file Read-Only through Windows Explorer. This doesn't prevent viewing, only from saving/editing.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
If you use Vault, your ilogic files are self-acting Read-Only.
Only works for External Rules.
