How to integrate iLogic error message into VB.NET code?
liminma8458
liminma8458
Hi, everyone,
Just wondering whether there is a way to  integrate iLogic error message into VB.NET code.
   For example, if use following sentence to read the data from spread sheet.
    LengthFloat=GoExcel.CellValue("tank_data.xls", "Gauges",     "llg_arm_lgth")
    if there is no such cell of "llg_arm_lgth", the error message appears as in attached file.
    Right now I want to use "try...catch... end try" in the iLogic code. I can duplicate the first line of the warning message using VB.NET code, but I can not  reach the second line. Does the iLogic expose this error message through some function? or which VB.NET code does this job?
    Thanks a lot.
    Limin
Limin
Inventor pro 2026 64 bit; Windows 11 pro 64 bit version 24H2; Office 2016 64 bit
Check into My Apps:
iCable : Create Cables, Hoses, Tubes and Pipes Easily.
iCable Professional : Create and Edit Them, Quick, Easy and Much More.
iCable Electrical : Auto Router to Create Massive Cables Automatically for Electrical Cabinet.
MegaJerk
Dim myInt As Integer
Dim myDouble As Double
Try
	myDouble = 2147483647 ' or you could use Double.MaxValue .
	''' Since 2147483647 is the max size that a 32bit integer can hold
	''' if we add one to it, it should force an overflow error that we
	''' will capture in the Catch.
	myInt = myDouble + 1
	Catch ex As Exception
	''' We've declared that 'ex' will exist as our Exception.
	''' So if we do run into this Catch (because of some exception) we can
	''' easily translate that exception to a readable String by using
	''' the following method.
	MessageBox.Show(ex.ToString ,"Error Catch")
	''' Try setting up this exception catching in your own Try Statement
	''' and checking to see if it gives you the information that you're
	''' looking for.
End Try
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
xiaodong_liang
Autodesk Support
Autodesk Support
Hi liminma8458,
