How to check the direction of an extrude feature
How to check the direction of an existing extrude feature
kPositiveExtentDirection
 kNegativeExtentDirection
 kSymmetricExtentDirection
Vladimir.Ananyev
PartFeatureExtent object returns direction of its extrude feature.
Try this VBA code:
Sub ExtrusionDir()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oDef As PartComponentDefinition
  Set oDef = oDoc.ComponentDefinition
  Dim oExtrFeatures As ExtrudeFeatures
  Set oExtrFeatures = oDef.Features.ExtrudeFeatures
  Dim oExtrFeature As ExtrudeFeature
  Set oExtrFeature = oExtrFeatures.Item(1)
  Dim oExtrDef As ExtrudeDefinition
  Set oExtrDef = oExtrFeature.Definition
  Dim oExtent As PartFeatureExtent
  Set oExtent = oExtrDef.Extent
  Dim oDir As PartFeatureExtentDirectionEnum
  oDir = oExtent.Direction
    ' PartFeatureExtentDirectionEnum:
    'kNegativeExtentDirection  = 20994
    'kPositiveExtentDirection  = 20993
    'kSymmetricExtentDirection = 20995
End Sub
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thank you
