Extract single Assembly from iAssembly
Ralf_Krieg
Advisor Advisor
Ralf_Krieg
Hello
I have an iAssembly, with a Sub-iAssembly and iParts. Is it possible to "extract" a copy of one configuration as normal assembly? So that I have an assembly where I can modify parts without touching the iAssembly or iParts.
R. Krieg
RKW Solutions
www.rkw-solutions.com
philippe.leefsma
Hi Krieg,
here is a VBA sample:
Private Sub CreateAndMoveiAsmMember()
    Dim factoryDoc As AssemblyDocument
    Set factoryDoc = ThisApplication.Documents.Open("C:\Temp\iAsmFactory.iam")
    Dim factory As iAssemblyFactory
    Set factory = factoryDoc.ComponentDefinition.iAssemblyFactory
    Dim row As Long
    row = 1
    Dim member As iAssemblyMember
    Call factory.CreateMember(row)
    Dim srcFilename As String
    srcFilename = factory.MemberCacheDir + "\" + factory.TableRows(row).DocumentName
    Dim destFilename As String
    destFilename = "C:\Temp\" + "NewMember1.iam"
    Call ThisApplication.FileManager.CopyFile(srcFilename, destFilename)
    'Delete the original file, if you'd like to
    Call ThisApplication.FileManager.DeleteFile(srcFilename)
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Ralf_Krieg
Hello
No, i don't want to simple copy a child. I want to make a copy of the factory part and delete the linked table to have a "normal" part. The same i want to do with an iassembly that contains another iassembly and both contains i parts. All of them should be copied and transformed to normal parts and assemblys.
I found a way to do this, but as expected all contraints are gone. That's ok, fixing all occurences is enough.
R. Krieg
RKW Solutions
philippe.leefsma
I am not sure what kind of solution you are talking about, could you share it with us?
Thank you,
Philippe.
Philippe Leefsma
Ralf_Krieg
Hello
Here's the code. Seem's in Inventor 2008 it throws exceptions or tells an iAssembly is an Assembly or an iPart is a Part and so on. In Inventor 2011 it runs fine in every test i made. Without any guarantee
Option Explicit
Private Sub ExtractAssFromiAss()
    Dim oApp As Inventor.Application
    Set oApp = ThisApplication
    If oApp.Documents.Count = 0 Then
        MsgBox "An assembly must be open", vbExclamation
        Exit Sub
    If Not oApp.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
        Exit Sub
    Dim oSourceDoc As AssemblyDocument
    Set oSourceDoc = oApp.ActiveDocument
     Dim sBasePath As String
     sBasePath = GetBasePath(oSourceDoc)
    Dim sNewFileName As String
    sNewFileName = sBasePath & "\" & GetDocumentName(oSourceDoc) & "-separiert" & Right(oSourceDoc.FullFileName, 4)
    Call oSourceDoc.SaveAs(sNewFileName, False)
    Dim oNewAss As AssemblyDocument
    Set oNewAss = oSourceDoc 'oApp.Documents.Open(sNewFileName)
    If ProcessRefedDocs(oApp, oNewAss, sBasePath) = False Then
        MsgBox "Error", vbCritical
    Call oNewAss.BrowserPanes.ActivePane.Update
    Call oNewAss.Update2(True)
    Call oNewAss.Save2(True)
    'Call oNewAss.Close()
End Sub
Private Function ProcessRefedDocs(ByVal oApp As Inventor.Application, ByVal oAssDoc As AssemblyDocument, ByVal sBasePath As String) As Boolean
Dim oRefedDoc As Document
Dim oRefedAss As AssemblyDocument
Dim oRefedPart As PartDocument
Dim oNewDoc As Document
Dim oFileSystem As Object
Dim sOldFileName As String
Dim oOcc As ComponentOccurrence
Set oFileSystem = CreateObject("Scripting.FileSystemObject")
For Each oRefedDoc In oAssDoc.ReferencedDocuments
    If oRefedDoc.DocumentType = kAssemblyDocumentObject Then
        'falls es eine iAssembly ist, extrahieren
        Set oRefedAss = oRefedDoc
        sOldFileName = oRefedAss.FullDocumentName
        If oRefedAss.ComponentDefinition.IsiAssemblyMember Then
            sNewFileName = sBasePath & "\" & GetDocumentName(oRefedAss) & "-separiert" & Right(oRefedAss.FullFileName, 4)
            If oFileSystem.FileExists(sNewFileName) = False Then
                Call ExtractiAss(oApp, oRefedAss, sNewFileName)
            If Not sNewFileName = "" Then
                For Each oOcc In oAssDoc.ComponentDefinition.Occurrences
                    If oOcc.ReferencedDocumentDescriptor.FullDocumentName = sOldFileName Then
                        Call oOcc.Replace(sNewFileName, False)
                Next
            For Each oNewDoc In oAssDoc.ReferencedDocuments
                If oNewDoc.FullDocumentName = sNewFileName Then
                    Set oRefedAss = oNewDoc
            Next
        Call processRefedDocs(oApp, oRefedAss, sBasePath) ' subassembly
    ElseIf oRefedDoc.DocumentType = kPartDocumentObject Then
        Set oRefedPart = oRefedDoc
        sOldFileName = oRefedPart.FullDocumentName
        If oRefedPart.ComponentDefinition.IsiPartMember Then
            sNewFileName = sBasePath & "\" & GetDocumentName(oRefedPart) & "-separiert" & Right(oRefedPart.FullFileName, 4)
                Call ExtractiPart(oApp, oRefedPart, sNewFileName)
        ElseIf InStr(oRefedPart.FullDocumentName, "DUMMY") Then
            sNewFileName = sBasePath & "\" & GetDocumentName(oRefedPart) & Right(oRefedPart.FullFileName, 4)
                Call oRefedPart.SaveAs(sNewFileName, False)
            Next
    sNewFileName = ""
Next
ProcessRefedDocs = True
End Function
Private Function GetBasePath(ByVal odoc As Document)
Dim oFileName As String
oFileName = odoc.FullDocumentName
Dim oArray() As String
oArray = Split(oFileName, "\")
Dim sName As String
Dim i As Integer
sName = oArray(LBound(oArray))
For i = 1 To UBound(oArray) - 1
    sName = sName & "\" & oArray(i)
Next
GetBasePath = sName
End Function
Private Function GetDocumentName(ByVal odoc As Document)
Dim sName As String
sName = oArray(UBound(oArray))
GetDocumentName = Left(sName, Len(sName) - 4)
End Function
Private Function ExtractiAss(ByVal oApp As Inventor.Application, ByVal oAssDoc As AssemblyDocument, ByVal sNewFileName As String)
Dim oParent As AssemblyDocument
Dim oRow As iAssemblyTableRow
Dim sMemberName As String
sMemberName = oAssDoc.ComponentDefinition.iAssemblyMember.Row.MemberName
Set oParent = oApp.Documents.Open(oAssDoc.ComponentDefinition.iAssemblyMember.ReferencedDocumentDescriptor.FullDocumentName)
Call oParent.SaveAs(sNewFileName, False)
If Not oParent.ComponentDefinition.iAssemblyFactory.DefaultRow.MemberName = sMemberName Then
    For Each oRow In oParent.ComponentDefinition.iAssemblyFactory.TableRows
        If oRow.MemberName = sMemberName Then
            oParent.ComponentDefinition.iAssemblyFactory.DefaultRow = oRow
    Next
Call oParent.ComponentDefinition.iAssemblyFactory.Delete
Call oParent.Save
oParent.Close
End Function
Private Function ExtractiPart(ByVal oApp As Inventor.Application, ByVal oPartDoc As PartDocument, ByVal sNewFileName As String)
Dim oParent As PartDocument
Dim oRow As iPartTableRow
sMemberName = oPartDoc.ComponentDefinition.iPartMember.Row.MemberName
Set oParent = oApp.Documents.Open(oPartDoc.ComponentDefinition.iPartMember.ReferencedDocumentDescriptor.FullDocumentName)
If Not oParent.ComponentDefinition.iPartFactory.DefaultRow.MemberName = sMemberName Then
    For Each oRow In oParent.ComponentDefinition.iPartFactory.TableRows
            oParent.ComponentDefinition.iPartFactory.DefaultRow = oRow
    Next
Call oParent.ComponentDefinition.iPartFactory.Delete
Call oParent.Save
oParent.Close
End Function
R. Krieg
RKW Solutions
philippe.leefsma
Well, unfortunately 2008 sounds like an old release already, the development team does not support that many releases back. I'm affraid that if the code works in 2011 and not in 2008, there is very little chance we can help at this time.
Philippe.
Philippe Leefsma
