- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Edit: Obviously I am talking about iLogic.
1st of all, I did a search in the forum and found threads discussed this topic.
However, my situation may be slightly different.
Here is what I am after.
- Looking for a way to untick all features in "Objects Visibility" in View tab (see snapshot below).
- Also hide those features mentioned above in locked files (e.g. they are not checked out from vault) in Assembly level.
Can it be done?
Thanks in advance.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
