Controlling Manage>Insert>Import with iLogic
will_roe
will_roe
Is there anyway to either automating the process Manage>Insert>Import when importing a .dwg in as far as it importing off a list of filepaths into a .ipt or replacing an already imported .dwg with another file?
I've already got the below.
'(ThisApplication.CommandManager.ControlDefinitions(”ControlDefinitionName”).Execute)'
CreateDwgUnderlayCmd
AppImportFileCmd
JelteDeJong
The most basic iLogic rule would look like this.
Dim dwgFileName = "C:\Path\to\your.dwg"
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oRefComponents As ReferenceComponents = oCompDef.ReferenceComponents
Dim oImportedDWGDef As ImportedDWGComponentDefinition = oRefComponents.ImportedComponents.CreateDefinition(dwgFileName)
Dim oImportedComponent As ImportedComponent = oRefComponents.ImportedComponents.Add(oImportedDWGDef)
This will place the dwg at the origin of your part. It will not be constrained to a face. Automatically constraining the dwg is difficult. but there is a workaround that might work for you.
Just run the rule and when it is finished you can redefine the location. That will constrain the dwg to a face.
Jelte de Jong
Blog: hjalte.nl - github.com
