Get Active Visual Style and store in a Variable
J.VandeMerckt
J.VandeMerckt
Hi Everyone.
I'm trying to retrieve the active visual style and store it in a variable for later use in my code.
Right now I can only change the visual style to chosen style.
Dim oView As Inventor.View = ThisApplication.ActiveView
oView.DisplayMode = DisplayModeEnum.kRealisticRendering
The idea is to change the visual style, then render and then revert the visual style back to the original one.
All help is welcome!
Andrii_Humeniuk
Hi @J.VandeMerckt . The View.DisplayMode function has a Gets/Sets property, so your code can get the active view. Here is an example:
Dim oActView As DisplayModeEnum = oView.DisplayMode
MessageBox.Show(oActView.ToString(), "Active Visual Style:")
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
J.VandeMerckt
This seems to be true.
Thanks!
