How to get the WorkSurfaces of a extruded surface (line no solid)
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
WCrihfield
Hi @bradeneuropeArthur.  I am not sure I understand, but maybe like this?
Dim oPDoc As PartDocument = ThisDoc.Document
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oExtFeat As ExtrudeFeature = oPDef.Features.ExtrudeFeatures.Item(1)
For Each oSB As SurfaceBody In oExtFeat.SurfaceBodies
	If oSB.IsSolid = False Then
		Logger.Info("Found the SurfaceBody.")
Next oSB
Dim oWSs As WorkSurfaces = oPDef.WorkSurfaces
For Each oWS As WorkSurface In oWSs
	If oWS.SurfaceBodies.Item(1).CreatedByFeature Is oExtFeat Then
		Logger.Info("Found the WorkSurface.")
Next oWS
Wesley Crihfield
(Not an Autodesk Employee)
bradeneuropeArthur
Thanks @WCrihfield That worked
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
