How to get surfacebody.Name in Apprentice?
zy19860604
zy19860604
I run the following code.
I get a error that I can't get surfacebody.Name.
Have you another way to get surfacebody.Name in Apprentice?
A.Acheson
Hi @zy19860604
Can you post the code?  With apprentice you don't have access to the inventor model so this might be the issue your facing. You can only do certain operations like read and write iproperties.
Regards
Alan
zy19860604
static void Main(string[] args) { Inventor.ApprenticeServerComponent invApprentice=new Inventor.ApprenticeServerComponent(); Inventor.ApprenticeServerDocument invDoc = invApprentice.Open(@"D:\FSMT_Vault\Project\S23G04\ZONE D\3d\STANDV-A-0615-P1081.ipt"); foreach(Inventor.SurfaceBody surfaceBody in invDoc.ComponentDefinition.SurfaceBodies) { Console.WriteLine(surfaceBody.Name); } //GetFaceAndEdgeInfo(invDoc); Console.ReadLine(); }
florian_wenzel
in Autodeks Inventor you need to start from [1] not from [0]
In Array or List, then from [0].
But all Edges, Vertex, Bodies, etc from [1]
zy19860604
In VB.Net start from(1). In C# start from [0]. I use C#. I think it is no problem.
florian_wenzel
it dosent matter or C# or VB.NET. i use also C#.
In my Opinion,  you are not able to get for example:
SurfaceBody oBody = oCompDef.SurfaceBodies[0];
start from 1
SurfaceBody oBody = oCompDef.SurfaceBodies[1];
But when you know Better, as you wish
zy19860604
I think the following code is no problem.
            Console.ReadLine();
