Auto Dimension Drawing: Retrieving Drawing View curve from part inside sub assembly
A.Acheson
Mentor Mentor
A.Acheson
Hi all, Having a little trouble working through this issue. I am trying to retrieve a drawing curve from a part inside a sub assembly. The code below works find when the part is inside an assembly but not if it is deeper inside a sub assembly. Any idea what the issue could be? Is it proxy related? for context the part is an ipart member so the ipart factory needs to be read to find the face in the member.
Errors out here.
Sub Main
	Dim drawDoc As DrawingDocument = ThisDoc.Document
	For Each drawSheet As Sheet In drawDoc.Sheets
		For Each drawView As DrawingView In drawSheet.DrawingViews
			Dim viewDoc As Document = drawView.ReferencedDocumentDescriptor.ReferencedDocument
		        ' Get the assembly document for the view.
				If viewDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
					Dim asmDoc As AssemblyDocument = viewDoc
					Dim occ As ComponentOccurrence
					For Each oDoc In asmDoc.AllReferencedDocuments
						Dim RefOccs As ComponentOccurrencesEnumerator = asmDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc)
							If RefOccs.Count = 0 Then Continue For
							occ = RefOccs(1)
			        'For Each occ As ComponentOccurrence In asmDoc.ComponentDefinition.Occurrences
			            If Not occ.Name.Contains("Part1") Then Continue For
							MessageBox.Show(occ.Name, "Title")
						' Get curve, location of each dimension leg start point.
						Dim curve1 As DrawingCurve = GetCurve("Part1_Left", occ, drawView)
						Dim curve2 As DrawingCurve = GetCurve("Part1_Right", occ, drawView)
						Dim tg As TransientGeometry = ThisApplication.TransientGeometry
						Dim pt1 As Point2d = tg.CreatePoint2d(curve1.StartPoint.X + 2, curve1.StartPoint.Y)
						Dim genDims As GeneralDimensions = drawSheet.DrawingDimensions.GeneralDimensions
						Dim dim1 As LinearGeneralDimension = genDims.AddLinear(pt1, drawSheet.CreateGeometryIntent(curve1), drawSheet.CreateGeometryIntent(curve2))
						dim1.CenterText
					Next
				Else
					MessageBox.Show("Is a part view Skiping", "Title")
					Continue For
			Next
	   Next
End Sub
' Work through either part or ipart looking for named faces then the curves.
Function GetCurve(faceName As String, occ As ComponentOccurrence, drawView As DrawingView) As DrawingCurve
  'https://modthemachine.typepad.com/my_weblog/2020/09/get-named-face-of-ipartfactory.html
  Dim doc As PartDocument = occ.Definition.Document
  Dim drawViewCurves As DrawingCurvesEnumerator
  Dim drawCurve As DrawingCurve
  Dim partFace As Face
  Dim partFaceProxy As FaceProxy
  Dim namedEntities As NamedEntities
  If doc.ComponentDefinition.IsiPartMember Then
	  Dim factoryDoc As PartDocument = doc.ComponentDefinition.iPartMember.ReferencedDocumentDescriptor.ReferencedDocument
	  namedEntities = iLogicVb.Automation.GetNamedEntities(factoryDoc)
	  partFace = namedEntities.FindEntity(faceName)
	  For Each f2 As Face In doc.ComponentDefinition.SurfaceBodies(1).Faces
	    If f2.ReferencedEntity Is partFace Then
			' Get the face into the context of the assembly
	      	occ.CreateGeometryProxy(f2, partFaceProxy)
			' Finds the drawing edge that represents the one with the named entity.
			Try
				drawViewCurves = drawView.DrawingCurves(partFaceProxy)
			Catch
				Logger.Info("Error getting DrawViewCurves")
			End Try
			Try
				drawCurve = drawViewCurves.Item(1)
			Catch
				Logger.Info("Error getting DrawViewCurve")
			End Try
			Return drawCurve
	      Exit Function
	  Next
 Else
		namedEntities = iLogicVb.Automation.GetNamedEntities(doc)
		' Get the face into the context of the assembly.
		occ.CreateGeometryProxy(partFace, partFaceProxy)
		Return drawCurve
End Function
Regards
Alan
WCrihfield
Hi @A.Acheson.  Yes, I believe this is simply a proxy level related issue.  If that iPart member was within a sub assembly, inside the main assembly that the view is for, then you would simply need to 'get a proxy of the proxy' to get a reference to the proxy that is in the context of the top level assembly.  However, I can not be sure that the specific component you are working with is actually at that specific level in your overall assembly structure, due to something I am seeing in middle of this code that is a bit of a wildcard in my head.  You get all referenced documents of the main assembly to a variable, then get all referenced components within the main assembly that references that one referenced document, without knowing which specific document it is, then simply get the first referenced component in that collection.  If I knew that was only component like that in the entire assembly structure, that would simplify things a bit, and everything would likely be OK.
Wesley Crihfield
(Not an Autodesk Employee)
A.Acheson
Hi @WCrihfield
Thank you for the response, yes there is only one occurrence in the sub assembly so no extra occurrences to deal with. I did use also a recursion method to retrieve the occurrence in another trial but with the same result.
Regards
Alan
lmc.engineering
Hi @A.Acheson
I made a couple of tweaks so this works at all levels now, and I ditched the proxies in favour of generic object, letting Inventor sort out the proxy mess.
Sub Main
				Dim OccEnum As ComponentOccurrencesEnumerator
				OccEnum = asmDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(asmDoc.ComponentDefinition)
				For Each Occ As ComponentOccurrence In OccEnum
					If Not TypeOf Occ.Definition.Document Is PartDocument Then Continue For
					Dim curve1 As DrawingCurve = GetCurve("Part1_Left", Occ, drawView)
					If curve1 Is Nothing Then Continue For
					Dim curve2 As DrawingCurve = GetCurve("Part1_Right", Occ, drawView)
					If curve2 Is Nothing Then Continue For
					dim1.CenterText
				Next
			Else
				Continue For
		Next
	Next
End Sub
	Dim partobj As Object
		Try
		Catch
			Return Nothing
		End Try
				occ.CreateGeometryProxy(f2, partobj)
				Try
					drawViewCurves = drawView.DrawingCurves(partobj)
				Catch
				End Try
				Try
				Catch
				End Try
				Return drawCurve
				Exit Function
		Next
	Else
		Try
		Catch
			Return Nothing
		End Try
		Try
			occ.CreateGeometryProxy(partFace, partobj)
		Catch
			Return Nothing
		End Try
		Return drawCurve
End Function
Only thing I haven't done is test with an iPart, but should work all the same.
Regards
A.Acheson
Hi @lmc.engineering
Thanks for the response. Getting as far as here and stopping. A mystery.
Regards
Alan
A.Acheson
So it seems the error was in the ipart where a face was modified later by a cut extrusion therefore converting the face into multiple faces. It is necessary to loop through reference entities and check the face there while also wrapping everything in a try catch for faces without multiple entities. Without it only suppressing the face allowed the face to be found without error.
		  Dim namedEntities As NamedEntities = iLogicVb.Automation.GetNamedEntities(factoryDoc)
		 Try
			Logger.Info(namedEntities.NameExists(faceName) &" - " & faceName)
		Catch
			Logger.Info("Error getting face entity")
			Return Nothing
		End Try
				Try
					' Face we are looking for has been cut by a feature so will have more than one reference entity,
					' So loop through the Collection
					For Each entity As Face In f2.ReferencedEntity
						If entity Is partFace Then
							Logger.Info("Found Face")
							Try
							Catch
							End Try
							Try
							Catch
							End Try
							Return drawCurve
							Exit Function
					Next
				Catch
					Logger.Info("Error")
				End Try
			Next
End Function
Regards
Alan
