How to get PartDocument object from mouse selection by vba?
I have an active assembly, where I would like to select a part or subassembly by clicking on model (not browser). How can I get PartDocument or AssemblyDocument object from mouse selection?
Sergio.D.Suárez
Hi, here is an example of how to access through VBA. When you select a component in the graphic window or in the navigator tree you will see the name of the file.
Sub Select_Component()
    Dim oCC As ComponentOccurrence
    Set oCC = ThisApplication.CommandManager.Pick(16643, "Select Component")
    'kAssemblyLeafOccurrenceFilter 16643 Assembly leaf occurrence filter.
    'kAssemblyOccurrenceFilter 16640 Assembly occurrence filter.
    Dim oDoc As Document
    Set oDoc = oCC.Definition.Document
    MsgBox (oDoc.DisplayName)
End Sub
Here the same action with ilogic.
Dim oCC As ComponentOccurrence = ThisApplication.CommandManager.Pick(16643, "Select Component")
Dim oDoc As Document = oCC.Definition.Document
MessageBox.Show(oDoc.DisplayName)
I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
