How to get Access to Variable Project file
andreas_schleif
andreas_schleif
how do I get access to the variable owner and release ID of the project file ( .ipj ) in such a way that I can display it on a drawing, for example?
I would like to make the variables available via the iProperties.
Many thanks for your support
Andreas
vpeuvion
This may be able to help you. It's not recent, but still works on my 2023 version.
https://inventortrenches.blogspot.com/2012/07/ilogic-and-inventor-project-file.html
Hope this will help you. Vincent.
nstevelmans
Hi, Try this in a drawing
Dim DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject
Dim oOwner As String = DesignProject.Owner
Dim oId As String = DesignProject.ReleaseId
iProperties.Value("Custom", "Owner") = oOwner
iProperties.Value("Custom", "releaseID") = oId
'MsgBox(oOwner)
'MsgBox(oId)
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Stakin
Thisapplication.DesignProjectManager.Projects.ActiveProject
andreas_schleif
Thank you
