Get subObject from Object by name
Hubert_Los
Hubert_Los
I would like to get a subObject from Object by name using C#. Previously, I used the VBA function: "CallByName(obj, propertyName, VbGet)".
I can get primitive objects such as strings and booleans, but I have a problem with non-primitive objects. I tried using Reflection, but I don't know why it doesn't work. Has anyone tried, retrieve elements like this? Maybe the Inventor library has a function that does this. I think it does but I can't find it.
        public static void GetObjectProperties(object obj)
            System.ComponentModel.PropertyDescriptorCollection oProps = System.ComponentModel.TypeDescriptor.GetProperties(obj);
            foreach (System.ComponentModel.PropertyDescriptor oProp in oProps)
                object propertyValue = oProp.GetValue(obj);
                if(propertyValue != null)
                    if (propertyValue.GetType().IsPrimitive || propertyValue.GetType() == typeof(string))
                    else
                        Type mainType = obj.GetType();
                        PropertyInfo subObjectProperty = mainType.GetProperty(oProp.Name);
                        object subObjectValue = subObjectProperty.GetValue(obj);
            return;
Michael.Navara
Use Reflection to call member by name is possible, but in my opinion it is the last chance how to Sava A Day.
Here is small example how to obtain ComponentDefinition or NULL from any document.
public void Main()
    var document = ThisDoc.Document;
    var componentDefinition = GetComponentDefinition(document);
    var surfaceBodies = componentDefinition.SurfaceBodies;
private ComponentDefinition GetComponentDefinition(Document document)
    //(document as PartDocument).ComponentDefinition
    //(document as AssemblyDocument).ComponentDefinition
    try
        var componentDefinition = document.GetType().InvokeMember(
            "ComponentDefinition",
            BindingFlags.Public | BindingFlags.Instance | BindingFlags.GetProperty,
            null,
            document,
            null);
        return componentDefinition as ComponentDefinition;
    catch
        return null;
