Does anyone know how to check out a file from the vault browser in Inventor using iLogic?
I can check-in, and check on the top level assembly with iLogic, but I cannot figure out how to check a part out from the vault tab.
We cannot use the Model Browser tab, as it is a referenced Solid Edge file and there are no options for vault when you RMB on the part in the Model Tab.
The image shows the Vault tab in the browser, and that we would like to check out the Solid Edge File (245731-customer.asm) and then check it back in. I have also added an image showing the RMB options from the Model Tab.
Any help would be great.
