How to Delete feature below end of part in inventor using vb.net or VBA
umesh.mhaskar
umesh.mhaskar
           I want to Delete feature below end of part,
           any one can tell me how to do this using vb.net or VBA
Umesh
umesh.mhaskar
Try
Dim objpartdoc As PartDocument
objpartdoc = objapp.ActiveDocument
If objpartdoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim objPartCompDef As PartComponentDefinition
objPartCompDef = objpartdoc.ComponentDefinition
'Dim part = objPartCompDef.Occurrences.Item(1).Constraints.Item(1)
Dim objBrawserpanes As BrowserPanes
objBrawserpanes = objapp.ActiveDocument.BrowserPanes
Dim browserPan As Inventor.BrowserPane = (From _Pan As BrowserPane In objBrawserpanes Where _Pan.TreeBrowser Select _Pan).FirstOrDefault
Dim DoDelete As Boolean = False
Dim ObjCollection As ObjectCollection = objapp.TransientObjects.CreateObjectCollection()
For Each _node As BrowserNode In browserPan.TopNode.BrowserNodes
If DoDelete Then
Dim obj = _node.NativeObject
ObjCollection.Add(obj)
End If
Dim def = _node.BrowserNodeDefinition
Dim x = def.Label
If x.ToUpper().Contains("END OF PART") Then
DoDelete = True
End If
Next
objPartCompDef.DeleteObjects(ObjCollection)
Else
MessageBox.Show("Please Open Part Document...")
End If
CAD_CAM_MAN
You may try using the command manager.
This worked for me...
'Set the end of part as needed...
'oPartDoc.ComponentDefinition.Features.Item(X).SetEndOfPart
'Where oPartDoc is your part document and X is the position
'you want to set the end of part.
Dim CDef As ControlDefinition
				CDef = InventorApp.CommandManager.ControlDefinitions.Item("PartDeleteBelowStopNodeCtxCmd")
				CDef.Execute()
