Ilogic to fill category in iproperties based on conditions
Hi all,
I want to fill the Summary >  category tab in iproperties of the parts of an assembly based on a certain logic.
If the part is sheet metal only
then enter "LC + thickness mm" in the category tab of that part.
If the part is sheet metal and has bending only
then enter "LC + thickness mm + BEND" in the category tab of that part.
If the part is sheet metal and has tapped holes only
then enter "LC + thickness mm + TAP" in the category tab of that part.
Thanks for your help.
Sid,
Using inventor 2011
RodrigoEiras
