How to delete existing user parameters
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I have a iLogic created which is fine (thanks for help I got from one of the postings). However, I also need to amend the same to delete existing generic single value user parameter (UP_GenSV) and existing multi-value user parameter (UP_MV). Pl. help. See the attached file.
Vladimir.Ananyev
Could you please try this iLogic code
'Parameter name:
Dim Name As String = "AAA"
Dim oDoc as Inventor.Document = ThisDoc.Document
Dim oDef as ComponentDefinition = oDoc.ComponentDefinition
Dim oPar As UserParameter = oDef.Parameters.UserParameters.item(Name)
oPar.Delete
oDoc.update
MsgBox("DONE")
This works for user parameters of any type.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
RoyWickrama_RWEI
It worked so nicely. Great. Thanks a lot. However, please note that, I am planning to do a lot. So, more are to come (but slowly).
