How to customise view names on drawing with ilogic
linuskotte
linuskotte
Hi all,
I have a one drawing sheet in that sheet i placed 10 part profiles.
I want to give names for each part like-Part numberXquantityXmaterial.
Please how to give this with ilogic.
Thanks in advance.
Linus kotte
MechMachineMan
Are you just talking about using sketched symbols attached to the part profiles by leaders?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
linuskotte
Some what like that only but i want automatic.
When I placed any view in the sheet automatically it should be displayed like below.
MechMachineMan
If you want it for all views, then yes, you will have to write a program
to insert and attach sketched symbols at some location given each view.
Good luck.
Justin K
salariua
I use a leader text symbol. and you can have just the text show up and it moves with the view.
http://blog.ads-sol.com/2014/10/part-info-on-dxf-exports.html
in the video loot at min 9:00 (or so)
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
If so please use the Accepted Solutions or Like button - Thank you!
