How to check dimension is attached to silhouette edges
Lalchetaketan022
Lalchetaketan022
Hi
I just got type of dimension and it's text. Need to know to what it is attached to. Is it possible to get this idea? I am looking for filtering diameter dimensions attached to silhouette edges.
basautomationservices
The class 'LinearGeneralDimension' has two properties, IntentOne and IntentTwo. They both have a dynamic property Geometry, from here you can retrieve the model geometry / curve type, etc.
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Lalchetaketan022
thanks for response.
I am trying on C++ and could not find relevant API. Is there separate community for same or this place is ok for C++ API query as well?
The API is the same, just iLogic is a bit different, but it uses the same API too.
The only C++ reference I know is: http://www.ransensoftware.com/Inventor-CPP/index.html
Lalchetaketan022
Thanks. You are correct. C++ does have an option of GeometryIntent found from LinearGeneralDimension.
Now I am again stuck to get this class LinearGeneralDimension. Actually I have GeneralDimension got from sheet. I could not directly assign GeneralDimension to LinearGeneralDimension. How to get LinearGeneralDimension?
