Hide curve in drawing view by iLogic
artemijs.nille
artemijs.nille
I have created an entity "AnsaugDKanteDSAussen " in 3d model of a part.
Dim Blatt_1 = ThisDrawing.Sheets.ItemByName("Blatt:1")
Dim ANSICHT23 = Blatt_1.DrawingViews.ItemByName("ANSICHT23")
Dim AnsaugDKanteDSAussen = ANSICHT23.GetIntent("AnsaugDKanteDSAussen")
In the picture below you can see this curve in the drawing view.
How can i hide this curve by iLogic?
basautomationservices
Once you found the curve (segment) you can set its visibility. You need to do this on the 'drawingCurveSegment' and not the 'DrawingCurve'
Dim activeSheet As Sheet
activeSheet = ThisApplication.ActiveDocument.activeSheet
Dim crv As DrawingCurveSegment
crv = ThisApplication.CommandManager.Pick(kDrawingCurveSegmentFilter, "pick curve")
crv.Visible = False
Contact me for custom app development [email protected]. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
artemijs.nille
Thank you for a reply.
In your solution i have to pick the curve, that i want to hide, MANUALLY.
How can i do it without manual picking, but by assigning my entity  "AnsaugDKanteDSAussen" to this "DrawingCurveSegment"?
I know, this was just an example. You need to retrieve the drawing curve from that intent, and then hide the segments that compose this curve.
artemijs.nille
I am sorry but i dont understand how should i do that.
My Intent is:
Dim AnsaugDKanteDSAussen = Deckscheibe.GetIntent("AnsaugDKanteDSAussen")
 how can i retrieve the curve from the Intent "AnsaugDKanteDSAussen"?
Ralf_Krieg
Hello
Dim oDrawCurve As DrawingCurve = TryCast(AnsaugDKanteDSAussen.Geometry, DrawingCurve)
If oDrawCurve IsNot Nothing Then
	Dim oDrawCurveSegment As DrawingCurveSegment
	For Each oDrawCurveSegment In oDrawCurve.Segments
		oDrawCurveSegment.Visible = False
	Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
artemijs.nille
Hello krieg,
thank you very much again.
it works perfeckt
