BSP Taper Internal hole for Content Center parts
engilic
engilic
I am trying to make Ball valves in the content center with BSP Taper Internal hole.
The problem is that it can not be made (at least not by me) and controlled by parameters in Family Table like every other hole or thread.
When going to Family Properties and trying to map parameters in Template Parameters there are options for Type, Designation, Pitch but BSP does not have them it has only Type, Size, and Designation (which is not editable).
I tried all possible combinations and had no success, also tried to find a part in default cc with BSP anything to see how Autodesk did it, but no success. JIS threads were done by linking to Thread: Nominal Diameter but that did not work either. As I said I tried everything I could think of.
I get an error that says that part cannot be made, the best case when linking to Thread: Nominal Diameter was that thread or hole did not change, just stays the same as the default model, no matter what I specify in the table, but that's no good.
So does anyone knows how to control BSP holes or threads at least in cc?
A.Acheson
@johnsonshiuemight be able to assist with moving this post to the inventor forum and with a possible solution.
Regards
Alan
