Edit Chamfer Precision with iLogic
workexperience5BMQQ
workexperience5BMQQ
I'm attempting to make a rule which will edit the precision of selected Chamfer Notes.
I am able to change the Linear Precision Enum as the MessageBox outputs a different value when I change it but it has no effect on the actual precision which is displayed on the chamfer note on the drawing. So I have no idea what the problem is.
Here is the code so far. Thanks in advance!
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oChamferNote As ChamferNote
Dim oSSet As SelectSet = oDoc.SelectSet
For Each oChamferNote In oSheet.DrawingNotes.ChamferNotes
	oChamferNote.DimensionStyle.LinearPrecision = 41729
	oChamferNote.DimensionStyle.AngularPrecision = 42241
	MessageBox.Show(oChamferNote.DimensionStyle.LinearPrecision)
Next
basautomationservices
For me your rule works fine. Maybe the view is not refreshing? Does it update when you move the view containing this dimension?
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
workexperience5BMQQ
No, sadly it still doesn't change when I move it.
I have however found that my work place has a style setup to change the Chamfer Precision.
So I updated the rule to change the style of the Chamfer instead.
Here it is if someone will find it useful:
Dim oStylesMgr As DrawingStylesManager = oDoc.StylesManager
Dim oDimStyle As DimensionStyle = oStylesMgr.DimensionStyles.Item("Name of Style")
	oChamferNote.DimensionStyle = oDimStyle
Next
 Thanks.
