How to change the name of a part when imported by Ilogic Place component
andrescastellanosint
Message 1 of 11
Hi.
I created a piece parameterised and with form of ilogic, but when it is opened by  place ilogic component i cannot choose the name of the part that I desire. How to change the name of a part when it is imported by ilogic place component?
Replies (10)
Message 2 of 11
bradeneuropeArthur
Could you do that on the save event or any other event?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
bradeneuropeArthur
like this:
Public sub main
Dim oInvDocInvDsgnTrcPrpPropSet As PropertySet
Dim strPartNumber as string
set strPartNumber = "XYZ"
Dim oInvDocInvDsgnTrcPrpPartNumberProp As [Property]
oInvDocInvDsgnTrcPrpPropSet = oInvDoc.PropertySets.Item("Design Tracking Properties")
oInvDocInvDsgnTrcPrpPartNumberProp = oInvDocInvDsgnTrcPrpPropSet.Item("Part Number")
oInvDocInvDsgnTrcPrpPartNumberProp.Value = strPartNumber
End sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 11
Hello when I run in VBA I get that does not recognize strPartNumber
Message 5 of 11
What do you mean with recognize?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 11
bradeneuropeArthur
Public sub main Dim oInvDocInvDsgnTrcPrpPropSet As PropertySet Dim strPartNumber as string set strPartNumber = "XYZ" Dim oInvDocInvDsgnTrcPrpPartNumberProp As [Property]
set oInvDocInvDsgnTrcPrpPropSet = oInvDoc.PropertySets.Item("Design Tracking Properties") set oInvDocInvDsgnTrcPrpPartNumberProp = oInvDocInvDsgnTrcPrpPropSet.Item("Part Number") oInvDocInvDsgnTrcPrpPartNumberProp.Value = strPartNumber End sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 11
bradeneuropeArthur
You need to add set to every declaration
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 11
Message 9 of 11
Remive the set for spartnumber.
For all other add the set
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 11
bradeneuropeArthur
Sorry for the incomplete code:
For VBA:
Public Sub main()
Dim oInvDoc As Document
Set oInvDoc = ThisApplication.ActiveDocument
Dim strPartNumber As String
Dim oInvDocInvDsgnTrcPrpPartNumberProp As Property
Set oInvDocInvDsgnTrcPrpPropSet = oInvDoc.PropertySets.Item("Design Tracking Properties")
Set oInvDocInvDsgnTrcPrpPartNumberProp = oInvDocInvDsgnTrcPrpPropSet.Item("Part Number")
End Sub
or Ilogic:
Public Sub main()
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 11
Hello friend Excuse me if I can not run the rule, I really do not know what happens. The ILOGIC rule throws an error that is shown in the imageaaaa.png
