How to change kReferenceBOMStructure appearance occurence
gustavo.cassel
gustavo.cassel
Hello, i want a way to change every appearance of a occurence that is in kReferenceBOMStructure, and disable the appearance substitution when its on kNormalBOMStructure.
Here is a code that I made to loop through all document occurences and test his BOMStructure type.
Sub Change_Reference_Color
	Dim Assembly_Doc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oAsmCompDef As AssemblyComponentDefinition = Assembly_Doc.ComponentDefinition
	Dim oRefDocs As DocumentsEnumerator = Assembly_Doc.AllReferencedDocuments
	Dim oRefDoc As Document
	'Dim MainAssetDoc As Assets = Assembly_Doc.Assets
	'Dim Reference_Asset As Asset = MainAssetDoc.Item("Azul - Tinta de Parede - Com Brilho")
	Dim oCompOcc As ComponentOccurrence
	For Each oRefDoc In oRefDocs
		For Each oCompOcc In oAsmCompDef.Occurrences.AllReferencedOccurrences(oRefDoc)
			If oCompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
				MsgBox("reference: " & oCompOcc.Name)
			Else
				MsgBox("normal: " & oCompOcc.Name)
		Next oCompOcc
    Next oRefDoc
	Assembly_Doc.Update2(True)
End Sub
Now I need a way to change this:
Of every part in reference, and
remove every appearance changes to the kNormalBOMStrucure occurences.
Thanks for the attention
A.Acheson
To assign appearance to the occurrence that is in the assembly document. Just reinstate your previous declaration of Reference_Asset.
' Assign the asset to the occurrence.
		  Try
			oOcc.Appearance = Reference_Asset
Catch
End Try
Remove the overide by setting the source type back to the part. Api sample showing its use here
oOcc.AppearanceSourceType = kPartAppearance
Regards
Alan
gustavo.cassel
Hi, i've created a new asset for referenced parts
But when i try to assign it to the occurence it gives me a error called "wrong paramenter" (err.number = 5).
	Dim Reference_Asset As Asset = ThisApplication.ActiveMaterialLibrary.AppearanceAssetCategories.Item("Padrão").Assets.Item("REFERÊNCIA")
				oCompOcc.Appearance = Reference_Asset
			Else
				oCompOcc.AppearanceSourceType = kPartAppearance
		Next oCompOcc
	Next oRefDoc
If you could help me i would be grateful!
A.Acheson
Here is the API sample for appearances. It could be the case that you haven't copied the appearance asset to the assembly. Here is how to copy an asset to assembly.
Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
	Dim libAsset As Asset = assetLib.AppearanceAssets.Item("Bamboo")
	Dim localAsset As Asset
	Try
		localAsset = Assembly_Doc.Assets.Item("Bamboo")
	Catch
		localAsset = libAsset.CopyTo(Assembly_Doc)
	End Try
Also you can loop through the assembly occurrences using
For Each oCompOcc As ComponentOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
No need for the loop through documents also.
Regards
Alan
