Creating Ilogic table
jsteinkeATFRB
Observer Observer
jsteinkeATFRB
Observer
Observer
I created a table in a template and it works great, no problems at all. See code below
InitializeTable()
    Dim row As TableValues
    Dim found As Boolean = table.TryGetValue(SPEED+","+HWY_HEIGHT+","+GROSS_LOAD, row)
    If (found) Then
        PART_SELECT= row.AY
		MAIN_SPRING= row.TV
Public table As New Dictionary(Of String, TableValues)
Sub InitializeTable
    table("600,0-350,6500-6999") = New TableValues("C42933001", 186)
    table("600,0-350,7000-7499") = New TableValues("C42933001", 183)
End Sub
Class TableValues
    Public AY As String
    Public TV As String
    Public Sub New(AY As String, TV As Double)
        Me.AY = AY
		Me.TV = TV
    End Sub
End Class
Now I am making another template and using the same code except
I am adding 2 extra columns. When I run the rule I get an error message.
Rest of the code is the same and I do not know what I need to fix to make it work. What is the solution to this
Dim found As Boolean=table.TryGetValue(SPEED+","+HWY_HEIGHT+","+GROSS_LOAD+","+GOV_POSITION+","+MACHINE_TYPE, row)
table("200,0-350,7000-7499,Left,Geared" ) = New TableValues("C42932001", 193)
Michael.Navara
For concatenation of strings use '&' instead of '+'. Or better solution is to use String.Join method
jsteinkeATFRB
Observer
Observer
So I did switch the plus for the & and it fixed the error message but now something is broken, when I change a parameter my output (main spring) does not change, the change isn't recognized. I haven't tried the String.join yet I am not sure how if will affect the rest of the code.
Michael.Navara
This looks like a iLogic Parameters Hell.
You can try to add some logging and look when the rule is executed. My expectation is the rule is NOT executed after parameter change.
If I'm right, you can try to fix it. Assign parameter value to variable. Like the following example for SPEED
Dim speedValue = SPEED
