Capturing hole qty's in a part.
wfisher
Message 1 of 9
wfisher
Looking for a way to capture the hole qty in a part file so that I can subtract (1) from it and add to a dimension the qty of spaces. Any direction on how to accomplish this would be appreciated. Using vb.net. Thanks
Replies (8)
Message 2 of 9
A.Acheson
Are you looking to reach into the part file and insert information in the drawing? Or are your trying to modify the part only? A little more information would better target a solution that suits your needs.
Regards
Alan
Message 3 of 9
JelteDeJong
I assumed that your holes are in a pattern. Try running the following rule and first select a hole line and then the associated dimension.  (btw this does not work for flat pattern views)
Dim manager As CommandManager = ThisApplication.CommandManager
Dim curveSegment As DrawingCurveSegment = manager.Pick(
    SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a curve")
Dim curve As DrawingCurve = curveSegment.Parent
Dim edge As Edge = curve.ModelGeometry
Dim view As DrawingView = curve.Parent
Dim refDoc As PartDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
Dim patterns = refDoc.ComponentDefinition.Features.RectangularPatternFeatures
For Each pattern As RectangularPatternFeature In patterns
    Dim patternFound = pattern.Faces.Cast(Of Face).
        SelectMany(Function(f) f.Edges.Cast(Of edge)).
        Where(Function(e) e Is edge).
        Any()
    Dim patternFound2 = pattern.ParentFeatures.Cast(Of PartFeature).
        SelectMany(Function(pf) pf.Faces.Cast(Of Face)).
        Any()
    If (patternFound Or patternFound2) Then
        Dim dimension As DrawingDimension = ThisApplication.CommandManager.Pick(
            SelectionFilterEnum.kDrawingDimensionFilter, "Select a dimension")
        Dim count As Integer = pattern.XCount.Value - 1
        dimension.Text.FormattedText = String.Format("{0} x <DimensionValue/>", count)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Message 4 of 9
wfisher
Thank you for the reply. I placed your code into a button and got the following error. Any suggestions?
Message 5 of 9
wfisher
Thank you for your reply. Working from the idw I would like to be able to select one dimension and have it show how many spaces for the qty of same holes (pattern) in the part.
Message 6 of 9
JelteDeJong
The variable "e" (green) in the lambda expression hides the argument "e" (red) of the function. this is not allowed. I would change the argument variable (red) because you don't use it. For example you can change it to "eventArgs"
Jelte de Jong
Message 7 of 9
wfisher
Changed the "e" to "a". New error. Sorry for all the novice questions.
Message 8 of 9
JelteDeJong
Not sure what this message means but I expect that it has something to do with the LINQ commands used. Therefore I rewrote the rule to not use LINQ (but way too many nested loops 😉 Give it a go and let me know.
    Dim patternFound As Boolean = False
    For Each f As Face In pattern.Faces
        For Each e As edge In f.Edges
            If (E Is edge) Then
                patternFound = True
        Next
    Next
    For Each pf As PartFeature In pattern.ParentFeatures
        For Each f As Face In pf.Faces
                If (E Is edge) Then
                    patternFound = True
            Next
        Next
    Next
    If (patternFound) Then
Next
Jelte de Jong
Message 9 of 9
wfisher
Magnificent Job! Works just liked I'd hoped. Thank you very much for your help. I tweaked the string format to meet my needs. I will study the rest of the code you provided and learn something new. I attached a small video showing it in action.
