How to change button displayname
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
How can I change the displayname/text of a button or other solution.
The displayname object is readonly...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JelteDeJong
You could simulate this by deleting the button and creating a new one. With the script below I made a button with a rolling text. (I did run this from an external application. I could not make it work from iLogic)
Sub main()
    Dim buttonText = "Rolling Button "
    Dim ribbon As Ribbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Assembly")
    Dim ribbonTab As RibbonTab = ribbon.RibbonTabs.Item("id_TabManage")
    Dim ribbonPanel As RibbonPanel = ribbonTab.RibbonPanels.Item("iLogic.RibbonPanel")
    Dim rollingButtonTemp = CreateRollingButton(buttonText)
    Dim control = ribbonPanel.CommandControls.AddButton(rollingButtonTemp)
    Try
        For index1 = 1 To 10
            For index = 0 To buttonText.Length
                Dim part1 = buttonText.Substring(0, index)
                Dim part2 = buttonText.Substring(index)
                buttonText = part2 + part1
                control.Delete()
                Dim rollingButton = CreateRollingButton(buttonText)
                control = ribbonPanel.CommandControls.AddButton(rollingButton)
                Thread.Sleep(500)
            Next
        Next
    Catch ex As Exception
    End Try
    control.Delete()
End Sub
Private Function CreateRollingButton(txt As String)
    Dim conDefs As ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions
    Return conDefs.AddButtonDefinition(
        txt,
        "MyButton InternalName" + Guid.NewGuid.ToString(),
        CommandTypesEnum.kEditMaskCmdType,
        Guid.NewGuid().ToString(),
        "MyButton DescriptionText",
        "MyButton ToolTipText")
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
bradeneuropeArthur
Same thought. I was searching for something else. But I think indeed this is the only option.
Thanks for confirmation and you helping hand.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
