How to Add New Collum in Content Center Itens by Code?
welinton.zanotto
Message 1 of 8
welinton.zanotto
Hello everyone,
I have a question about the possibility of programmatically adding new columns to existing items within the Content Center. I need to add these 2 new columns to all items, and I would like to do it via an API, is that possible?
I am trying with the code below, but when executing cf.TableColumns.Add it returns an unhandled error. Please, is the code correct, or is there another way to do this? Thank you in advance!
[TestMethod]
public void AddCollums()
string id = "Inventor User Defined Properties";
// Content center itens
ContentTreeViewNode treeViewTopNode = InvApp.App.ContentCenter.TreeViewTopNode;
var fm = treeViewTopNode.ChildNodes["Recursos"].ChildNodes["Bicos pulverizadores"];
foreach (ContentFamily cf in fm.Families)
Console.WriteLine("\t" + cf.DisplayName);
cf.TableColumns.Add("ModelCode", "", ValueTypeEnum.kStringType,false,false, id, "ModelCode");
cf.TableColumns.Add("ModelName", "Nome", ValueTypeEnum.kStringType,false, "{PARTNUMBER}", id, "ModelName");
cf.Save();
Replies (7)
Message 2 of 8
bradeneuropeArthur
First you need a read/write family.
Do you have that?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
welinton.zanotto
Hello Arthur, thank you for your response.
Yes, the library is set for read/write, and I'am able to manually add and remove items or columns using the CC Editor.
Message 4 of 8
bradeneuropeArthur
Ok!
Could you give me the complete familyname?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
welinton.zanotto
yes, the names are in my code, commented alongside the methods
is this what you asked for?
[TestMethod]
// Contentcenter itens
Console.WriteLine(fm.FullTreeViewPath); // Recursos:Bicos pulverizadores
Console.WriteLine(fm.DisplayName); // Bicos pulverizadores
Console.WriteLine("\t" + cf.LibraryName); // MCL VALE
Console.WriteLine("\t" + cf.DisplayName); // BICO INOX 304 UMICONTROL MOD. UM-4-10 CM Ø2,8MM
Console.WriteLine("\t" + cf.MemberDirectory); // BICO INOX 304 UMICONTROL MOD. UM-4-10 CM Ø2,8MM ANGULO 60° 1-8 MACHO BSP
//// **** this CODE below fails *****
cf.TableColumns.Add("ModelCode", "", ValueTypeEnum.kStringType, false, false, id, "ModelCode");
cf.Save();
Message 6 of 8
bradeneuropeArthur
So this is the FamilyName, correct?:
And this the columns to be added?:
ModelCode
ModelName
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
bradeneuropeArthur
@welinton.zanotto
This will work:
Sub main
Dim oContentCenter As ContentCenter= ThisApplication.ContentCenter
Dim a As ContentTreeViewNode = oContentCenter.TreeViewTopNode
loopCC(a)
	End Sub
	Public Sub loopCC(c As ContentTreeViewNode)
		Dim f1 As ContentFamily
		Dim  id As String = "Inventor User Defined Properties"
		For Each c In c.ChildNodes
			If c.Families.Count > 0 Then
				For Each f As ContentFamily In c.Families
					If f.DisplayName = "BICO INOX 304 UMICONTROL MOD. UM-4-10 CM Ø2,8MM"
						f1 =f
						MsgBox(f1.DisplayName & " " & f1.IsModifiable)
						f1.TableColumns.Add("ModelCode", "", ValueTypeEnum.kStringType,False, ,id , "ModelCode")
						f1.TableColumns.Add("ModelName", "Nome", ValueTypeEnum.kStringType,False, "{PARTNUMBER}", id, "ModelName")
						f1.Save()
					Exit For
				Next
			Else
				loopCC(c)
			Next
	End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
tgregory3G7FA
bradeneuropeArthur wrote:
@welinton.zanotto
This will work:
Sub main
loopCC(a)
	End Sub
						f1 =f
						f1.Save()
					Exit For
				Next
			Else
				loopCC(c)
			Next
	End Sub
This code does exactly what I'm looking for.  Only issue I have is it takes a long while to iterate through all sub categories.  Is it possible to target it directly to a sub category?
