How does one access assembly parts parameters using VBA?
All I have is iLogic or VBA.
Not VBA.Net. Straight inventor VBA.
How do you do this in VBA?
This obviously is iLogic
SyntaxEditor Code Snippet
Parameter("XSpacer11", "XspacerX") = -XOffset + TP
 What is the equivalent syntax using VBA?
MechMachineMan
As an FYI,
iLogic is simply using calls in a "simplified" Vb.net environment
Internal/External Rules can be coded in iLogic or VB.Net
Macros must be coded in VBA.
The difference between VB.net and VBA is fairly minimal; there are some objects advanced users use that are accessible in VBA and not Vb.net and vice versa. Other than that, you need Set statements in vba, and do not have access to Try/Catch error handling in VBA.
Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
bshbsh
AFAIK, there's no straight equivalent syntax for this. It would be something like this:
Set oComp = ThisApplication.ActiveEditDocument.ComponentDefinition.Occurrences.ItemByName("XSpacer11")
For each Item in oComp.Definition.Parameters
if Item.Name = "XspacerX" then
Item.Value = -XOffset + TP
exit for
end if
AFAIK there's no "ItemByName" function for Parameters, at least not in IV2014. But I could be wrong.
@bshbsh Thanks
I think that is close and kind of what I envisioned.
I get a compiler error, oComp "Not defined"
I searched the class library for ItemByName and got 4 hits.
None of them solved the error.
If I can just crack this issue of "getting to" my part parameters, then I could do anything.
bshbsh
It's because you might have "Option Explicit" on, meaning you have to explicitly define all variables first - what I didn't do beacuse I used to remove the "option explicit". So you either remove it too, or define oComp first:
Dim oComp as ComponentDefinition
Thanks again bshbsh.
You're right.
I found some code here that is very close to what I am after.
http://forums.autodesk.com/t5/inventor-customization/change-user-parameter-custom-property-with-vba/...
Thanks for getting me to look in the right places.
All I had to do was change User to Model and now I am able to at least debug.print all my parameters.
I'll see today if this gets me home.
