How do I run a rule in one assembly to load and modify a second assembly?
ron.c
ron.c
I want to run a rule in one assembly to load and modify (do a Component Replace) a second assembly.
I'm actually using the first assembly as a template to create 30 clones, incrementing the name of the new assemblies 1 through 30, which makes it easy to use them in for or while loops.
My problem is that even after opening the newly cloned assembly for editing Component.Replace ("Old_Component:1", "New_Component.ipt". True)  replaces the component in the original assembly, rather than the new assembly.
I have tried using MakePath, but that does not seem to help.
Any ideas?
Thanks!
MechMachineMan
Sounds like you might be better off using the direct API call rather than the iLogic. If you look up ReferencedFileDescriptor.ReplaceReference() it will provide you with a more explicit way of replacing references.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
ron.c
I'm not having any problem replacing the component using:
Component.Replace(OldComponentName, NewComponentName, True)
My problem is running that rule from one assembly and making component replace in a second assembly.   You see, the same rule first makes a copy of the first assembly, then changes a component reference in the newly created copy.
 I have not been able to find any good documentation for ReferencedFileDescriptor.ReplaceReference()
- Ron
