How do I customize the Right Mouse Click options under the marking menu?
shastu
Advisor Advisor
shastu
In 2012 the Open Drawing was available directly under the marking menus.  Now in 2014 it is under the component sub-menu.  How can I move it back?  See attachment for clarity.
LukeDavenport
Hi Shastu,
Nice and easy - see picture below:
[image: Inline image 2]
LukeDavenport
And with image this time!
Luke
shastu
You are showing the marking menu.  That is not what I am talking about.  For example, when you do it from the browser, you don't see the marking menus at all.  Instead you just have the RMC options.
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Acadmauto,
Normally, the RMB menu (called linear menu in API) can be customized at
UserInputEvents.OnLinearMarkingMenu( SelectedEntities As ObjectsEnumerator,
        SelectionDevice As SelectionDeviceEnum,
        LinearMenu As CommandControls,
        AdditionalInfo As NameValueMap )
Where, LinearMenu tells the controls. You can add more controls, or remove controls.
So, what I thought is your requirement could be achieved by the code below:
Private Sub inputEvents_OnLinearMarkingMenu(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal LinearMenu As CommandControls, ByVal AdditionalInfo As NameValueMap)
          ‘remove the control, but get its control definition
          Dim oContrlDefToMove As ControlDefinition
           Dim eachCtrl As CommandControl
           Dim eachSubCtrl As CommandControl
           For Each eachCtrl In LinearMenu
            If eachCtrl.DisplayName = "Component" Then
                For Each eachSubCtrl In eachCtrl.ChildControls
                    If eachSubCtrl.DisplayName = "Open Drawing" Then
                        Set oContrlDefToMove = eachSubCtrl.ControlDefinition
                        eachSubCtrl.Delete
                    End If
                Next
                End If
            Next
‘add the control definition to the location you want to put
           'Call LinearMenu.AddButton(oContrlDefToMove, , , LinearMenu.Item(1).InternalName, False)
End Sub
 but, when I tested,  most controls of UI are available in the LinearMenu, but no control for "Open Drawing" 😞  I have not got what happened with the method, but this is the only API way I can think of for your requirement.
