Error in rule
Error in rule
GosponZ
Error in rule
GosponZ
I do have in Exel only one column with few Client names, and i have this rule. Guys i need you help to help me understand why this warning is up and after continue  rule is working correct. What i need to fix? Thanks
myXLSX = "C:\Customer.xlsx"
GoExcel.Open(myXLSX)
ForrowNumber = 2 To 1000
If (GoExcel.CellValue("A"&rowNumber) = (""))Then
lastUsedRow = rowNumber- 1
EndIf
Next
'set the list to be read from the XLS file
DimmyArrayListAsNewArrayList
i = 2
'add the values from the Excel file to an array list
DoUntili = lastUsedRow+1
myArrayList.add(GoExcel.CellValue("A"&i))
i = i+ 1
Loop
'present the list to the user
myCust1 = InputListBox("Select Customer from list", myArrayList,myArrayList.Item(0), "iLogic", "Customer")
'set the iProperty
iProperties.Value("Summary", "Company") = myCust1
rossano_praderi
Hi, I've made few modifications to your code and now run without errors.
'myXLSX = "C:\Customer.xlsx"
GoExcel.Open("C:\Customer.xlsx", "Sheet1")
lastUsedRow = 2
Dim myArrayList As New ArrayList
While GoExcel.CellValue("A" & lastUsedRow) <> ""
		myarraylist.add(GoExcel.CellValue("A" & lastUsedRow))
	lastUsedRow = lastUsedRow + 1
End While
myCust1 = InputListBox("Select Customer from list", myArrayList, myArrayList, Title := "iLogic", ListName := "Customer")
'set the iProperty
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
GosponZ
thank you and  indeed working well.
