How do I change the transparency of a composite w/ VBA
JBEDsol
JBEDsol
I have a large assy from a vendor that's all surfaces.  I want to write a code that traverses the assy and changes all the composites full of surfaces from transparent to non transparent.  I can't find the object/property to do this.  Any ideas.
Sergio.D.Suárez
Hi, is this what you are trying to achieve?
This will remove the transparency of all your worksurfaces
Dim oDoc As Document = ThisDoc.Document
For Each oWS As WorkSurface In oDoc.ComponentDefinition.WorkSurfaces
oWS.Translucent = False
Next
 I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Sergio.D.Suárez
What I shared before is an ilogic rule code, here you have the same code in VBA.
Sub Translucent()
    Set oDoc = ThisApplication.ActiveDocument
    Dim oWS As WorkSurface
    For Each oWS In oDoc.ComponentDefinition.WorkSurfaces
    Next
End Sub
I hope it is useful. Regards
Mechanical Designer
SteveK88
I Made it as a toggle...
 If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
    MessageBox.Show("This must be a PART document !", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Error)
    Return
	If oWS.Translucent = False
		oWS.Translucent = True
	Else
Next
