Add column in parameters
sreed
sreed
I came across another user's post on the forums and I noticed in a picture that he attached that in his Fx parameters he has a custom column called Rule driven.   My question is how do I get this same column into my template?  Attached is the picture.
Sergio.D.Suárez
Hi, are you familiar with the ilogic rules?
You must have at least one ilogic rule that works with some parameter of your part file. This column shows you which parameter is controlled by some ilogic rule.Here I show you some descriptive images of a simple example
I hope I was clear. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
