Export Current Part Flat Pattern to DXF with Custom name
vkulikajevas
vkulikajevas
I need to create Flat Patern of one opened Sheet metal and save it in this pattern:
Stock Number " " Thickness " " Material
The code works to save DXF (It is a remake of code that saves all assembly parts to DXF), the problem is in the naming. I can't seem to change the sFName to name in needed pattern.
Can you help me with this?
Sub Main()
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_INTERIOR_PROFILES"
' Get document's full file name
Dim sFname As String
sFname = oDoc.FullFileName
' The file format will depend on the extension
' Set file name extension to ".DXF"
sFname = Left$(sFname, Len(sFname) - 3) & "dxf"
oCompDef.DataIO.WriteDataToFile( sOut, sFname)
End Sub
Sergio.D.Suárez
Hi, try the following code, I think it does what you need. Run it in a sheet metal file
	Dim oDoc As Document = ThisDoc.Document
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
			oCompDef.Unfold
		Else
		Try
			oMaterial = oDoc.ComponentDefinition.Material.Name
			oThickness = Round(oDoc.ComponentDefinition.Thickness.value*10, 2)'Convert cm to inch
			oStockNumber = oDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value
			Dim oFilename As String  = ThisDoc.Path & "\" &  oStockNumber  & "_" & oThickness  & "_" & oMaterial & ".dxf"
			MessageBox.Show(oFilename)
			Dim oDataIO As DataIO = oDoc.ComponentDefinition.DataIO
    		oDataIO.WriteDataToFile("FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_INTERIOR_PROFILES", oFilename)
			oCompDef.FlatPattern.ExitEdit
		Catch
		End Try
I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
