How can I mark canvas and change their color by selecting from the list
maciej0202g
Message 1 of 22
maciej0202g
Hello everyone, can anyone 2021-12-09 15_36_58-Autodesk Inventor 2015 - [Część_1].pngtell me how to write code in ilogic that will mark each plane with a color
Replies (21)
Message 21 of 22
WCrihfield
Here is a very simplistic iLogic rule you can use to create those two needed custom iProperties, so that you can put them into your Form.  I am using the Expression, to set their value to always be equal to the other standard iProperties, so that they will stay up to date.
iProperties.Expression("Custom", "Density_") = "=<Density>"
iProperties.Expression("Custom", "Mass_") = "=<Mass>"
Results:
Wesley Crihfield
(Not an Autodesk Employee)
Message 22 of 22
maciej0202g
Good morning.
Point A - they work 👍
Point B - I have made only a drop-down list, is it possible to choose the type of material here
Point C - an example element weighs 9.5 kilograms, is it possible to move the comma
