How to Create a Macro Enabled Excel File - Help!!!
munderwood4GRE6
munderwood4GRE6
I'm trying to export assembly info into a newly created excel file using a macro enabled excel template.
I get the following error.
The code I have seems to run just fine when I'm using a regular excel template.
myXLS_File = "C:\...FilePath.xls"
excelWorkbook =  excelApp.Workbooks.Add (Template: = "C:\Temp\Best_Excel_Template_Ever.xlt")
excelWorkbook.SaveAs (myXLS_File)
But when I use .xlsm and .xltm file extensions for macro enabled excel docs I get the error.
Any help is greatly appreciated!
A.Acheson
I think the problem lies in that you need to switch the file format to .xlsm and not simply put that in the file name. In testing manually  saving a macro from a macro template it defaults to .xlsx file type instead of .xlsm, user has to change the format type manually. So changing the format through code is required also. Here is a link to retrieve the integer for  file format.
Change the template path in the below code
Imports System.Windows.Forms
Imports System.IO
Imports Microsoft.Office.Interop.Excel        'To use excel
Sub Main
	Dim oMacroTemplate as String ="Enter fullfilename.xltm"
Dim fName As String = ThisDoc.PathAndFileName
Dim xlwb As Workbook Dim xlws As Worksheet 'Start a new instance of Excel, make visible and disable alerts Dim excelApp As Object excelApp = CreateObject("Excel.Application") excelApp.Visible = True excelApp.DisplayAlerts = True 'Open Excel template Try xlwb = excelApp.Workbooks.Add(Template :=oMacroTemplate) 'xlwb = excelApp.Workbooks.Add (oMacroTemplate)'This works also xlwb._SaveAs(FileName := fName, FileFormat := 52)'xlOpenXMLWorkbookMacroEnabled- using this text does not work in place of integer 'or 'xlwb._SaveAs(fName, 52)'This works also 'Syntax 'SaveAs(FileName, FileFormat, Password, WriteResPassword, ReadOnlyRecommended, CreateBackup, AccessMode, ConflictResolution, AddToMru, TextCodepage, TextVisualLayout, Local) Catch MessageBox.Show("Cannot find XL File: Exiting", "iLogic") Exit Sub End Try End Sub
Regards
Alan
