Hole Table iLogic
Hole Table iLogic
Hole Table iLogic
I posted on the main forum, but it hasn't gotten any traffic. Hopefully someone here can help me out.
https://forums.autodesk.com/t5/inventor-forum/ilogic-hole-table-replace-character/m-p/7131747#M64635...
Thank you!
MechMachineMan
Is your hole table the standard hole table from Inventor?
Custom solutions demand details....
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Yes. Thanks!
MechMachineMan
SyntaxEditor Code Snippet
Sub Main()
    Dim oHoleTable As HoleTable = ThisDoc.Document.ActiveSheet.HoleTables(1)
    For Each oRow In oHoleTable.HoleTableRows
        oRow.HoleTag.Text = oRow.HoleTag.Text.Replace("T", "R")
    Next
End Sub
Justin K
Thanks a bunch @MechMachineMan!
I think you probably just saved me a weeks worth of monotony.
FYI for anyone else that comes along in the future: the bigger your hole table, the longer this will take. The code checks every line in the table, if it's not a T_ hole it moves on to the next hole. If it is a T_ it replaces the T with an R. My 400 hole hole table took about 5 minutes for the program to run.
