Hole ifeature
Hole ifeature
sbalasubramanianJJDFU
Hole ifeature
I am trying to create an ifeature hole for dowel pin from midplane with two different diameters and depth in either direction on a single sketch point and plane if required. Appreciate some guidance and direction for this case. thanks!
bradeneuropeArthur
Via coding?
Can you share an example?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
